SMALL RUBBER WASHERS........where to buy???
I am looking for a source for small rubber washers.....for #2 and #4 sized screws/bolts. I checked micro fasteners, RTL fasteners, Fastenal, Graingers, etc. I have purchased some at Lowes before but I believe they were #6 size. Anybody have any sources?
thanks,
Steve
thanks,
Steve
SC
RE: SMALL RUBBER WASHERS........where to buy???
The hardware store and your home improvement stores sell assortments. o-rings, washers and some kind of plastic/felt material washers.
I want them to use on canopy mounting screws. I have used the fuel tubing for years....functional but not very pretty. I think most o-rings may be a little hard to provide the anti-vibration quality that rubber washers or fuel tubing gives. The grommets are an option but will have to track them down as well.
If I cant find the washers no biggie.....just thought I would ask.
Steve
Steve
Airborne Models carries tiny silicone washers that are used for the canopies and cowls on the World Models planes. They also have a good selection of washer-headed screws for this application. The washer has a protrusion that fits in the hole in the part and keeps it in place.
See, for example http://ecsvr.com/abm/ShopDisplayproducts.asp?Search=Yes
I pull off some rubber washers from a steel siding pole barn project. The screws are around 3/16" OD, but could be used on maybe 4-40 and 6-32 screws. They are used to seal the water from getting in the roof or walls. They may be good for something?
My Feedback: (27)
ID
Like aspeed I have used the metal/ruberized washers. Right now I have several under the canopy screws (replaced the plastics with real metal) on my Escapade. Most businesses selling metal siding have these screws in a number of colors and in bulk so you don't have to buy a whole bunch......just remove the self tapping metal screws.
I bought a set of Hollow punches, Home Depot, Harbor Freight, offline, etc, and a sheet of flat rubber at Menards 1/16 inch. I use the size of punch that gives me the outside diameter I need and simply screw into the center.. I spent $13 for both and will never have to buy another rubber washer.
