Reload this Page >
How to braise piano wire
Old 05-11-2007, 09:42 PM
cslota
Default How to braise piano wire
I am making a new landing gearing out of piano wire so I can put my airplane on floats. I would like to know how to braise to wire together.
Old 05-11-2007, 10:03 PM
fancman
My Feedback: (16)
Default RE: How to braise piano wire
Here is some good info.
http://www.vaillyaviation.com/images...re%20_web_.pdf
ORIGINAL: cslota
Old 05-11-2007, 10:12 PM
TexasAirBoss
My Feedback: (22)
TexasAirBoss's Avatar
Super info !!!
Old 05-12-2007, 05:12 AM
cslota
Thanks for the link on how to bend and form wire using heat treating, I will save that. But what I am looking for is information on how to baze to seperate pieces of piano wire together. I want to attach a cross brace between the front landing gear and the rear landing gear supports for a set of floats.
Old 05-12-2007, 06:52 AM
fancman
My Feedback: (16)
The best way I have found and always done it is to get some soft thin copper wire and wrap the two pieces where you want to tie them together and then use silver solder to solder them together. This makes a nice joint that won't ever fail. There is no way to just braze the two pieces together other than welding, you need the wire wrap. Wind it on smoothly like putting on eye on a fishing pole and you'll have a great looking strong joint.
http://www2.towerhobbies.com/cgi-bin...&I=LXFS75&P=ML
ORIGINAL: cslota
Old 05-12-2007, 07:56 AM
aerowoof
braising gets the wire too hot and will lose it's hardness,silver solder is better but if you want to braize you will need an oxy acetylene torch and tanks plus braizing rod and flux then practice on scrap pieces.heat the braising rod tip a few inches and stick it in the flux so the flux sticks to the rod.then heat the metal to be joined red hot then touch the rod to the red hot metal till it melts and flows.let cool.in 40 years never had the need to braise music wire silver solder worked for me and I have the equipment to braize if I want to.
Old 05-12-2007, 08:01 AM
jetmech05
If you braze them together you will have that brass looking joint much better to solder
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
