Reload this Page >
Piggyback......
Piggyback......
Old 02-28-2003, 02:41 AM
crashman232
Default Piggyback......
How many people have tried towing sailplanes aloft by using winches put on other planes wings? I have tried it, with poor luck on both sides. Glider and "mule"(carrier). The mule was the Hangar 9 Xtra Easy. Stock engine and winch. Surprised me when it took off with a Hobbyshack Ridge Runt. The release failed and had to land with plane still there. When it did work, glider did not haver enough airspeed and fell like a rock. Tried the same winch (slightly modified) on an Avistar. Worked better, except that the winch feel apart and glider slid forward, being munched by prop. Haven't tried since. I take a high-start anyday.
Crashman
Old 02-28-2003, 11:49 AM
Tattoo
I built a small flatbat glider to put on the back of Kraut's Debby...it works GREAT!!! What a BLAST!!! Here's more on it:
http://www.rccombat.com/forum_2000/t...?TOPIC_ID=4352
Old 02-28-2003, 01:00 PM
Kaos Rulz
I've been towed a few times by a Sig Senior Kadet with wing sailplane harness. (I forget the brand name, but it was the type that looks like the framework of a rectangular box, with two releasable straps securing the sailplane wing)
The only problems we had was the mule had to be flown at a reduced speed. You want just enough speed to gain altitude, otherwise the sailplane can shift in the cradle. The mule needs to turn gently -- very gently, otherwise the sailplane wings will dip while on the cradle. This is especially true when towing large wings. ( 99 + inches) I found it best to turn using only rudder trim
for control until release of the sailplane.
I usually fly with power-pod, but an occasional tow is a great change of pace.
Old 02-28-2003, 03:21 PM
MinnFlyer
MinnFlyer's Avatar
Here's one easy way to do it. I'd be interested to see others.
Old 02-28-2003, 04:56 PM
FLYBOY
FLYBOY's Avatar
We do it both ways. The mother ship is a SR falcon with a rack on top. It works well but flys with rudder only when it has a glider on. I like both methods. The mother will not carry my Kamiak. Its too big. Gotta winch that one. Building new winch though. My old one is older than I am, and I am not that young. both work well though.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
