painting with latex paint
I've been doing some looking here but have not found a definitive answer for this question. On painting a plywood and balsa fuse, should a primer be applied or can latex be applied directly to the bare wood. There is all kinds of things about painting fiberglass and fabric, but not much on woods. It really seems like it would be best to prime the wood, but also seems like a lot of people spray latex directly to their project. A second question is on a vinyl surface, should a primer be applied to this and then painted or should just latex be applied?
KS
Other than a primer to seal the wood, can a sanding sealer be used that you could then prime and then paint latex? I realize by the time you get a clearcoat of something over the top you have 4 layers. What I am really asking is how do you seal and then finish a wood fuselage using latex? Seems like most people are covering fabric or glass when they are using latex. Maybe I need to glass it but is there another way to do it? Thanks for any additional info.
One fairly lightweight way to seal balsa before latex is to: 1) use a very dilute (skimmed milk consistancy) solution of water and Titebond II to attach a silkspan skin to the wood; 2) when dry, use a brushable mixture of water and spackling compound to "paint" the structure; 3) when that is dry, sand almost all of it off, leaving just enough to fill the grain or weave of the silkspan; 4) prime (I use Kilz II, a latex primer) and paint. I will try to attach a picture of my project done that way. Good luck, Dzl
I use silkspan the same way but use McCutchins wood sealer instead to get that good surface. It's like water and 2 coats sanded after each one and you are ready to go! Go to my web site and click on 'Pictures, look at the Corsair and you will see the end result. It wasn't painted with latex but the end result would be the same!
Hi,
Once we cover the balsa with a paintable plastic film, how do we then paint the model with latex? I am considering using my extra cans of house paint to paint my model in light and dark hues of blue with slate gray. Then, I am considering going with a clear coat to glow fuel proof it. It would seem to me that a brush would work fine, and that a sprayer would be too much trouble.
If it came to that, wouldn't it would be as or more favorable to buy some spray paint cans at the LHS?
