Identify this retract?
CA
Hello
I know this a kinda crappy picture, (scanned picture from manual) but can someone identify what brand/model this retract is? Picture is of steerable nose gear.
I am putting together a KMP Flycat,...its a new plane,.... no assembly threads on this plane yet, and the manual gives no reference as to what type of retracts to use. My friend Serge bought this plane, got a little frustrated with it, and gave it to me. He called KMP and they told him it was Hobbico retracts,....not true. Any help would be apreciated....thanks guys
RE: Identify this retract?
You are right, It's definitely not Hobbico. It's also not Robart. Why not just use a Hobbico retract? Robarts are great quality if you can afford a set. Spring Air, Great Planes, and Dave Brown are also good retracts.
CA
Thanks for the replies guys......Serge said he tried the Hobbico retracts,...but it moved the wrong way?...not quite sure what he meant by that...that it moved towards the fuse and not away?....hell,..I dunno...I need to ask him exactly what the problem with it was.
ORIGINAL: CrashPro
The Hobbico retracts work in the same direction as the illustration.
CA
hmmm....by the looks of this picture of the Hobbico retracts....it WOULD go the wrong way......they actually go the OPPOSITE way of in the illustration in first post
Does this nose gear have like a little semi-circle which extends maybe 1/8 inch beyond the surface of the plastic?
I saw such at a hobby show a few years ago, and they were rather inexpensive. With separately installed wire gear parts?
Wm.
Wm.
ON, CANADA
They are a chinese no-name retract, not available in North America.
So, what we're going to do is have one sent to Sierra Giant Scale, and have him design a retract to fit it.
CA
Thanks Paul....no need to call me now. I think in the mean time....I'll just make the mains retractable,(the Hobbicos work jut fine)...and the nose fixed.
George
George
My Feedback: (35)
Has anyone found retracts for this? I just icked one up and I owuld like to put retracts in it. How did you install the main gear retract servos? Seperate servos in the wing which will cause some modification to the wing or did you just put one servo in the fuse and leave the wing attached?
Scott
Scott
I bought a set like CrashPro showed from GreatHobbies here in Canada for under $30.cnd There for my TopFlite F4U 62". Upto 10-lb's or so... They work great!
Mike AM...
Mike AM...
