biggest plane you've ever put a .40 into
WA
RE: biggest plane you've ever put a .40 into
largest was a goldberg cub 76.5 inch wing weighed 8 lbs smallest was called a wingding Don't remember who made the kit any more but it looked sorta like a stik with a box fuse and a "T" beam tail boom about a 40 inch wing weighed 3.5 lbs. Yes, the .40 was the recommended engine for it. plane met its demise at the bottom of a screamin fast full throttle dive that should have been followed by a pull to vertical but instead only led to catastrophic failure of the left wing. [&o]
