Cowl gromments
NY
Cowl gromments
Does anybody know where i can get silicon grommets for my cowl, perferably clear or white grommets to match cowl color ?. Its for the Funtana 40 with a saito 82. The vibration is just too much for the mounting holes it just makes the holes bigger when not using any gromments. Any suggestions would be appreciated, thanks.
DC
DC
NY
RE: Cowl gromments
Hi, yes i thought of that too, but was hoping something more permanent that would stay in place something like the servo gromment with the groove around it.
My Feedback: (18)
RE: Cowl gromments
I have used the fuel tubing with some success but now I reinforce the inside of the cowl with a piece of light ply. It really beefs up the cowl and the screws wont cut through the ply like they do the cowl. If there are 2 screws in each side of the cowl I run 1 piece of ply down the inside of the cowl. Then on the fuse I run an equal length of ply to butt up against the ply on the cowl. I then use blind nuts and bolts to attach the cowl. That way instead of the cowl just being attached on four screws it is actually making ply to ply contact down both sides. Its comes out pretty sturdy and stands up well to vibration.
My Feedback: (20)
RE: Cowl gromments
try McMaster-Carr www.mcmaster.com I use the round servo grommets that went in the old Kraft servos and I think some Futaba. Use one of the brass servo eyelets too and your cowl wear problems will be over.
NY
RE: Cowl gromments
Gringo Flyer, placing lite ply on inside cowl and on fuse would create a big gap between cowl and fuse while i don't think it will look all that good. but i most likely try the fuel tubing trick, thanks.
RE: Cowl gromments
You can reinforce the inside of the cowl with your spare CA hinges..........If you have blind nuts for your cowl screws, use nylon instead of metal screws........Micro Fasteners has 4-40 and up in nylon.........less vibration related problems with nylon......they also have some neoprene backed stainless washers that I use with #2 button head black screws........super for areas with vibration issues.
