Reload this Page >
K&b .screemen .48
K&b .screemen .48
Old 03-10-2003, 05:55 PM
Wulf
Wulf's Avatar
Default K&b .screemen .48
I`VE GOT A G.P. CAP 231(63"SPAN).WITH A K&B .48 IN IT .CAN ANYBODY RECOMMEND THE RIGHT PROP FOR THIS SETUP.I REALIZE A 11X7 IS RECOMMENDED BY MANUFACTURE FOR GEN.FLYING.THE 11X7 LOOKS SMALL FOR THE PLANE .WILL IT WORK OR SHOULD I TRY AN 12X6?I HAVE NOT FLOWN PLANE YET.I`M TIRED OF TRAINERS AND THIS IS MY NEXT PLANE.
HOF
Old 03-10-2003, 06:01 PM
P-51B
P-51B's Avatar
I had one on a H9 advance when I was on a project out west. Altitude was about 4900 ft above sea level on the ground. I usually ran a 12x6 to 12x8 on it, and it had no problems turning well.
Haven't run it in a while, and don't have any tach numbers for you, sorry.
Old 03-10-2003, 07:54 PM
Wulf
Wulf's Avatar
Thanks for the comeback -I`ll give the 12x6 a whirl-
Hof
Old 03-10-2003, 09:20 PM
JohnBuckner
JohnBuckner's Avatar
APC 12.25 X 3.75 works well on the .48 with a clean airframe.
John
Old 03-14-2003, 02:33 AM
Azcat59
Considering the airplane as well as the engine, I would think a 12x6 would give you pretty good performance. You want good vertical, but you also need a decent speed if you intend to do knife-edge flight (point rolls, slow rolls, etc.) I think APC props are basically more efficient.
Clair Sieverling
Old 03-14-2003, 12:44 PM
Wulf
Wulf's Avatar
Thanks to all,
I have a 12x6 mounted on the Cap and all we need now is for some co-operation from the weather.
Hof
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
