Multiple servo control question help please.
My Feedback: (14)
OR
I am trying to set up 4 servo's to one channel. I have no choice but to do this. Is there a device out there that will take a signal and distribute it to multiple servos all dong the same thing? I am not sure how many servos could be stacked on a y harness. I would think only two.
Thanks in advance
Thanks in advance
1 Post
RE: Multiple servo control question help please.
Hi somajr,
Yes there are various devices out there that allow you to run multiple servos/batteries and set up their throws so they are identical. I use a "Smart Fly" from Precision Airobatics, JR make a "Matchbox" and there are many others. Like most things in this hobby your choice will be determined by budget, current and future applications.
With multiple high drain servos I would strongly suggest two large capacity battery packs and hevy duty switch/es.
Cheers,
Colin
Cheers,
Colin
you can run four on y harnesses....happens all the time in bipes..heres how 1 y to servo and another y, the second y to a servo and yet another y, the thrid y hook up the last two servos....3 y's 4 servos
