Aluminum Spinner Question
Do you know of any aluminum spinners (2-1/4") that fit APC props? Which aluminum spinners are the best price for the money... on towerhobbies there are about 4 different brands, but I don't know if they fit APC props or not.
-Brian
-Brian
My Feedback: (18)
MPI works!
I've used an MPI alum spinner on my 46 FX with props from 10x6 to 11x7 for the past 6 months or so. Just had to shorten the bolt a little. Only cost about $15 at LHS here. Don't know if you can get them at Tower though. Hope that helps!
Beau
Beau
Originally posted by JimTrainor
I have a Great Planes 2 1/4 spinner that fits an 11x5 APC prop.
hmmm never hear of MPI...must check that out.
-Brian
I bought the 2 1/4" great planes spinner and the adapter nut for my 4 stroker. The 12X6 will fit without any filing but will need a tiny amount of filing for the 13X6. Remember to file and balance it with the prop balancer.
Cheers
Cheers
Hey!
To fit prop in to spinner is simple as can be. Take Dremel multitool on you hand and start mill out the bigger prop holes. Easy? Of course itīs important to make holes same size, so spinner wont go inbalance.
My Feedback: (506)
Originally posted by Someone11
What about a bigger size prop like 12X6 or 13X6 for a YS 63?
-Brian
-Brian
I'm using a Tru-Turn 2.25" Jet-style spinner on my DP Ultimate 40. (Maidened yesterday!)
Tru-Turn double-nut adapter, YS .63 and an APC 13x6 prop. No additional cutting of the spinner necessary.
$29 bucks from Tower. http://www2.towerhobbies.com/cgi-bin...EARCH=truq1051
visioneer_one, I was looking into Tru-Turn spinners too. I wanted to buy the Tru Turn regular 2-1/4" spinner, but if the YS 63 jam nut kit doesn't fit on the regular 2-1/4" spinner then I will have to go with the Jet-Style spinner. BTW, is this the right adapter kit for a YS 63?:http://www2.towerhobbies.com/cgi-bin...?&I=LXKE13&P=V
Do you know if the YS 63 would fit in the regular 2-1/4" spinner?
Thanks for your help, and nice looking ultimate man!
-Brian
-Brian
Or is this the right adapter for a YS 63: http://www2.towerhobbies.com/cgi-bin...?&I=LXKE12&P=V
My other choice is?:
http://www2.towerhobbies.com/cgi-bi...P?&I=LXKE13&P=V
They both have the same thread pitch and size, but one is double lock... although there is a not on the bottom of the double locking adapter that says it will not fit under 2-1/2 . Is this true for the Jet style 2-1/4" tru turn spinner also?
-Brian
BTW, check these spinner out man! They look kick @$$, and they're not as expensive as tru turn.... what ya think: http://hobbyracer.com/mpi-11.htm
-Brian
My Feedback: (506)
According to Tru-Turn their double jam nut adapter will not work with their standard 2.25" spinner - the cone is too short. The Jet-style is the only one that will work in that size.
The double jam nut adapter can be used on all tru-turn spinner types sized 2.5" and up.
I'm using the 'LKXE13 Double Jam Nut Adapter Kit' on the above YS / Ultimate combo.
If you go with the 2.25" Jet spinner you might as well spend the exttra dollar and get the 120 version with the bigger prop slots. This spinner weighs slightly less than the standard-slotted version, and you'll have enough room to run wide-blade 3D props liks an APC 14x4 (if that's a consideration)
