Reload this Page >
Monokote Question
Monokote Question
Old 11-05-2007, 08:32 PM
starfire73
Default Monokote Question
I have about 10 or so flights on my Eagel 2 kit. I did the monokote myself, and this was my first time. I've noticed though that ever since the second or third flight, I'm having a heck of a time keeping my trim pieces on the covering. I used Monokote, Neon Green to cover the plane, then trimmed it in Metallic Blue Monokote. It keeps noticeably lifting a various edges, and some of the smaller peices have totaly come off. I've tried re-ironing them back down, but they've lifted again. I've tried a higher temp, a lower temp...
What am I doing wrong?
Old 11-05-2007, 08:43 PM
Campgems
Default RE: Monokote Question
Maybe using windex with amonia to clean the plane. I just found out that it was desolving the adheasive. DUHH, I've been using it to put down the trim and never thought about it lifting the edges.
Iron the edges again and then use a Qtip dampened with Aceton and lightly go over all the edges. This will seal down a bit better than the iron will. Watch though bucause if you have a little wrinkel along the edge, the stuff wicks under. I saw this and tried to press it down. THe adheasive is also the color for most of the Monokote colors. All the color went away where I touched it. You can also use a very fine capilary tube or pipette to seal the edge with CA.
Nice trim and color combo on the plane.
Don
Old 11-05-2007, 08:50 PM
skreamer
I like to use Monokote trim solvent instead of the iron for trim pieces. No bubbles and I have time to position my pieces. Cheap and a bottle lasts a lonnnng time.
Old 11-05-2007, 10:44 PM
starfire73
ORIGINAL: skreamer
Hmmm... I'll have to give that some thought. It has better hold than the heat activated adhesive on the monokote itself?
Old 11-05-2007, 10:45 PM
starfire73
ORIGINAL: Campgems
I haven't been using windex, or any glass cleaner/ammonia product.
Old 11-06-2007, 01:21 PM
spiral_72
spiral_72's Avatar
You've never lost that plane have you? WOW that's bright! [X(]
Old 11-06-2007, 03:57 PM
starfire73
ORIGINAL: spiral_72
No she stands out pretty good. The thing I like about it, is that it stands out in any sky condition. Cloudy, clear, low light - either way it's easy to see.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
