Glue to use
Glue to use
What glue should i use to attach my dummy pilot. It will be attached to lite ply, i've heard of using silicone but i am not sure! Any Suggestions?
Austin
Austin
RE: Glue to use
I'm with Minnflyer on this one. Every pilot I've attached without a screw has come loose, eventually. Had a full-body pilot warp, looked like he was leaning over to look through the gunsight, had to run a straightener up through his back. One time I used goop to tack a head down, and at the end of the season I hung the plane upside down for storage. A few months later, the head was laying in the canopy.
Too many things affect those pilot mountings, I'm using a screw or two on each one now.
Good luck,
Dave Olson
Good luck,
Dave Olson
QC, CANADA
RE: Glue to use
Ditto with the above two. Glue in a plywood plate, flush, in her 'tummy' void. then screw into it. Re-enforce the cockpit underside too, or a large washer to spread out the clamping force.
Give the arm hinges a bit of glue too. Sometimes there is enough vibration to get them arms in weird & unnatural positions.. creepy..
RE: Glue to use
I just finished after adding a yoke and a screw to hold her down as minnflyer suggested. I also added a little glue to her pivot points so she doesn't move her arms. Now I'm debating using scews or glue to fasten the canopy, if i do decide to use glue what should i use to do so?
Austin
Austin
