Paint Question
CT
Paint Question
[link]http://www.tompierce.net/190/html/paint.htm[/link]
Can I use Tom's procedure to prep the model and then paint with Klasskote or do I need to stick with the latex?
RE: Paint Question
The answer to your two part question is "Yes" then "No"
A properly applied and finished glass base is an excellent surface for any type of primer and subsequent paint finish.
Ed S
Ed S
CT
RE: Paint Question
Thank you Ed. This will be my first time doing it right (painting) as opposed to using covering so I just want to get it straight. I understand that latex paint is heavier than epoxy. Is this true?
Jim
Jim
RE: Paint Question
I cannot answer which is heavier. I have just started to experiment with latex paint. I painted some test pieces before I started on an airplane. Bare latex is not glow fuelproof. I then applied a waterbased polyurethane over the paint. that was not glow fuel proof either. The fuel stripped them both right off.
The blue airplane in the picture is an epoxy glass base, epoxy primer and then the automotive basecoat/clear coat process.
The wheel pants are epoxy glass with epoxy primer. The paint on them is ordinary latex and then automotive clear coat. Automotive clearcoat is fuel proof.
From the discussions I have seen Klasscoat is fuelproof.
Ed S
RE: Paint Question
ORIGINAL: somegeek
Can a person purchase automotive grade clear coat in an aerosol can?
somegeek
somegeek
By Automotive paint supply house, I don't mean your friendly local Auto Zone. Go to a real paint supply company. Every city of any size has at least one of them.
Bill, AMA 4720
WACO Brotherhood #1
RE: Paint Question
Ed S
