Battery Chargers
NC
Battery Chargers
What is a good charger for larger-size (1400 and higher) NiMH and NiCad batteries that is not a rapid, field charger and can charge multiple batteries at the same time?
RE: Battery Chargers
How about this :
http://www3.towerhobbies.com/cgi-bin...&I=LXEYD4&P=ML
It comes with a converter so you can use it at home or at the field charges 2 batteries up to i beleive 3 amp charge rate, will cycle discharge and all the fun stuff
can be used with Nicad/Nimh lipo/lio (note no balancing for the lithium batteries)
Steven
Steven
The accu cycle elite is a great charger but if you don't plan on getting lipos any time soon you can get the accu cycle that doesn't charge lipos.
http://www3.towerhobbies.com/cgi-bin...&I=LXL357&P=ML
