Futaba 6EXP Mixing
My Feedback: (41)
Futaba 6EXP Mixing
Can the Futaba 6EXP be used to mix an elevator with 2 servos so you dont have to use a dual servo reverser heres a link
http://www3.towerhobbies.com/cgi-bin...I=LXRXF3**&P=0
NB, CANADA
RE: Futaba 6EXP Mixing
That radio (assuming we're talking about the fm/pcm version) has one available programmable mix. You could put your second ele servo on channel 5 or 6 and mix it to channel 2, that may work. You'd just have to be careful about your channel 5 switch or 6 knob....
Might be best (read simplest) to use a reversing y.
NB, CANADA
That'd work fine. Gives adjustability at the cost of more weight than a simple reversing y harness.
This one still has a trim pot for the reversed servo:
http://www.greathobbies.com/producti...rod_id=MPI3169
J
J
