Servotray an bellcrank.For Rudder pull-pull
AR
Hello. I am wondering if i can use the 3152 Futaba digital servos hooked together in a servo tray for my rudder?
Will i have to have a servo programer for this? Or can i install them an go.
Any help would be great
AR
RE: Servotray an bellcrank.For Rudder pull-pull
This may have been better off in the radio forum. Moderator if your feelings are the same would you please....Thanks
CA
Edit: Read more carefully... Do you mean setting up a pull-pull with 2 servos, one pulling from each side? If so, I think you would have to program them. It would be the same thing effectivly as hooking them up to the same surface with a pushrod, the servos would have to match perfectly. (I think not an expert on digital servos)
This kind of thing? http://www.swbmfg.com/
Btw with there "New Self adjusting Servo trays" even if both servos are not running perfictly togeather they wont harm the servos ...
Steven (oo and with that you can ahve one servo lock up and stilll have function of the rudder...)
