Glow Chargers - Best Way To Clean 'Em
My Feedback: (40)
Hanger 9 Glow Chargers (with Meters) - All in service now several years, have collected a lot of lint and grit in the tube that slides over glow plug - the contacts are also quite dirty. What's the best way to clean the external contact and tube?
Also - these use Sanyo KR-1300SC cells (smaller than C cells). Hanger 9 does not sell replacements. Know of a reliable battery source catering to these cells? Thanks for all your help and my best to you all in '08.
RE: Glow Chargers - Best Way To Clean 'Em
Steel wool
also the contact in the tube (the one that hits the top of the plug) i have herd about it oxidization and some ppl have used a dremel to clean the inside with one of those wire brush attachments (like numbers 443/405 [link=http://www.mytoolstore.com/dremel/403-443.gif]here[/link])
I hope this helps
Steven
I hope this helps
Steven
I've pulled them apart and used rubbing alcohol first, to get rid of the grease. After that, I've lightly sanded the contacts with a very fine grit paper, wipe again with alcohol and reassemble. Steel wool would work great, too. I just didn't think of it at the time!
FL
If you can unscrew the barrel that contains the batt - do so. Now, while gripping the - aw heck. I'll just post some pics!
If yours is like the one I have (not a twist lock-on) just pull the outer sheath till it jams on the inner barrel.
Now twist off the barrel assy and everything comes apart. Just tap the inner barrel on a hard surface to free it from the outer sheath.
Clean with denatured alcohol or similar and put barrel assy back together.
The Cathode contact inside the housing usually gets corroded and must be cleaned. This is not as easy as it would seem. Scrape, grind, buff, sand - whatever you have to do to get it clean then put some anti-oxidant grease on it.
New cells can be had from just about anywhere that sells rechargeables. Tower, any of the battery supply houses found here, Panasonic, and I think you can get/order them through Radio SH***. They are the same size as the ones in your cordless tool battery packs. Just not really low impedence.
Hope this helps.
After your first outing using it it will be all lubed up again!
Hope this helps.
My Feedback: (40)
THANK YOU ~ THANK YOU ~ THANK YOU !
Jazzy - I took my chargers apart as you instructed, cleaned them and walla - heck of a tip!
Now to find replacement batteries and do a bit of winter flying before the really cold stuff sets in.
Have a GREAT 2008!
Have a GREAT 2008!
