FORMULA 560 CANOPY GLUE/ A QUESTION???????????
FL
I have a bottle of "Formula '560'" Canopy Glue. Will this be a satisfactory glue to attach a clear plastic canopy to Ultracote? I'm just finishing a kit build and have this glue on hand but have only used it once to insert a plastic window in a window frame. Thanks
CA
You may want to roughen the covering a little with some sandpaper just to give a little insurance. Probably not absolutely necessary but every bit helps. I've also poked pin holes in the covering wherever the glue will be to allow it to soak down to the wood. The problem with pin holes or cutting away the covering though is that you can usually see it through the edge of the canopy unless you add some sort of trim with striping tape or paint.
LA
I was talking to one of the guys at the field and he tryed GOOP . the only thing about it was make sure thats were you want it as its pretty tackey.
My Feedback: (18)
The canopy glue is great. I dont roughen up or do any other preparation to the covering other than cleaning it really well with alcohol.
My Feedback: (22)
I love RC560 ! But I didn't scuff the inside of the canopy or the covering on a plane once, and the canopy blew off in a knife edge. So, I believe that scuffing the surfaces to be glued is kinda mandatory now.
My Feedback: (8)
Although the product you mention will work, E-6000 is the best I have found for canopy glue. I get it at a chain craft shop called Michael's. It is the same stuff as PFM sold by Innovative Model Products.
It is far superior to any other canopy glue I have ever used.
560 is the best way to attached your canopy. As mentioned alcohol wipe your fuse and wash the canopy with water to remove any residue or oils from them. Use no more than needed and you may need to tape the canopy in place while the glues dries, usually overnight unless you have a very good fit. The PFM type glues are simply messy for this application.
FL
Thats the right glue but i prefer a different way to use it. I position the canopy on the fuselage and trace lightly around it, use a sharp knife and make a cut just inside the line and JUST through the ultracote not the wood! then make another cut about an 1/8 inch further in,remove the strip of covering to expose the wood under neath. Glue the canopy on and tape it. Leave it alone for 24hrs before removing the tape. It is ok to wipe off any glue runs with a wet cloth. Once dry I like to seal around the edge of the canopy with stripping tape of the same color, makes for a realy profesional install. Good luck.
AL
ORIGINAL: Steve Collins
My Feedback: (8)
The E6000 is water cleanup until it cures. No messier than any other type of glue. It will run a bit but is far thicker than the 560 stuff mentioned here which is very "runny".
For those who think it is messy to use, it can even be applied in small amounts to both surfaces to be joined and allowed to set up a bit. This eliminates any tendency to run and then it works similar to contact cement.
Ed Cobb,
Nice to see that someone else has discovered this adhesive. Amazing how when someone asks which is the "best" glue, you tell them, and they don't even try it. Try it once and you won't ever use anything else to glue a canopy on!
Ed Cobb,
My Feedback: (9)
NY
I have both sitting on my building shelf and when I absolutely, positively want it to remain stuck, I use the E-6000. That stuff works great. I also purchase mine at Michael's Craft Store. And anyone who likes to "dress up' their sport scale planes to look a bit more scale like should take a walk through your local craft store because you will find a huge selection of items that can be used to "doll up" your baby. I found a shapeable mesh material in there that is perfect for making radiator screens from. Brushes of any sort for any sort of paint or dope. Even stainless wire and ferrules for semi-functional scale flying wires. Check it out next time your wife wants to go get supplies for scrap booking or croucheting or such.
My Feedback: (8)
I once had a Jack Stafford P-39 used for pylon racing. It's canopy was glued on to Monokote with E-6000 (no roughing up or other preparation except for a good cleaning with lacquer thinner). On its second test flight something went wrong and it went straight in from a fairly high altitude at high speed.
You can imagine how torn up that fuselage was. The section where the canopy was had folded up like an accordion, including the canopy, but the gluejoint was 100% intact. This is why I am such a believer in this glue for canopies as well as a host of other applications.
Did I mention it is usually under $4 for a nice sized tube???? About the same price as the Formula 560 but you get twice as much!
I ran across this and since I having to reglue a canopy on a old airplane I ran to Walmart and picked up a tube. Only $2.75 for a tube. I know people have used 560 as a nylon hinge glue. I wonder how E-6000 would work for hinges?
I was just reading the instructions for E-6000. it says acetone or citrus based clean up. And containing perchlorethylene I would watch the fumes.
