Goldberg Sukhoi engine
RE: Goldberg Sukhoi engine
I had one with a Moki 1.35/BCM pitts. Very nice.
Before it a had the Extra in the same series. That had a 1.20 surpass II/pump.
The M' powered Sukhoi was far better in the power dept'.
Today I'd use an OS 1.60FX and an F3A muffler pipe set-up.
Bags of power. No drama.
Thats what I hate about BCM mufflers. They don't muffle. Just divert oil.
Well, I have decided on the engine that i am going to put in the Sukhoi.
and the winner is........ (DRUM ROLL)
LS-26cc Gasser
Weight 2.5Lbs including muffler and ignition
Cleaner too.
http://www.lsproengines.com/
Super tigre2350 Weight with muffler: 38oz / 2.4 pounds
I have read too many horror stories about the Super Tigre engines.
LS-26cc Gasser
Cleaner too.
My Feedback: (14)
TX
ORIGINAL: Bass1
It's a Saito 150 with a perry pump. The fuel tank is over the CG.
#32
Hey don't get me wrong, I'm interested in your choice!
These engines seem cheap, but the ignition/mount/muffler are all extra right?
What is the all up weight, muffler, mount/ign'/battery/switch?
#34
My Feedback: (14)
TX
ORIGINAL: Bass1
Gremlin Castle, What prop are you using on your 150s?
#36
Just picked up one of these at an auction. It seems to be in pretty good shape. I was thinking of putting the Saito 220 in it as it had a 150 in it originally and I happen to have a 220 sitting around. Looks like the previous owner had to add weight in the nose with the 150 so I'm hoping to be good with the 220. I will be using a rubber dampened mount for the engine and quarter scale servos on the rudder and elev as well as +100oz/in torque servos on the ailerons. I also will be using on board glow with a micro switch off the throttle servo. The kit is the 1st series with the gear mounted in the wing. I was thinking of running an 18x8 prop on the 220 as I have read other people getting good numbers and response with that combo. I have no experience with this particular plane or engine and any tips would be appreciated. By the way, I don't plan on flying it fast, just smooth.
#37
My Feedback: (14)
TX
ORIGINAL: cracker
#38
cracker , Did you get the black one with the red star on the tail , silver and black checkers ? If you did , I was one of the guys bidding against you. lol nice plane .
#40
My Feedback: (26)
Good day........... I had a 1.08, OS on mine and changed to a OS 120 four stroke and it works fine. The G-26 might be a little heavy. I even build an 80" foam, sheeted, and Monocoated wing to make it a big bird. The fuse I glassed and painted it. I hate Monocoat. Mine is a real floater. you really got to slow it down or it just goes flying on by.......... Thanks, Nick
#42
My Feedback: (26)
No, but I can take some if you would like. I have to do a little work tomorrow and I was just thinking about fly it tomorrow afternoon. E-mail me, [email protected] and let me know. I can take some with out any problem.
Thank you, Nick
Thank you, Nick
#44
NC
(Late entry to this thread). I purchased a partially built Goldberg Sukhoi 26 1.20 size without the sheet of plans. My question: what is the center of gravity for this plane? I've downloaded the instructions and have gone throuigh them 3-4 times and can't find the specifications for the center of gravity.
I plan to put an OS FS 120 surpass II engine in it mounted horizontally.
#45
Icantley, I'm looking at my plans booklet and I had penciled in some CG info. I wrote down "CG = 4 and 1/2 inches to 5 and 1/4 inches from leading edge at root. Then next to that I wrote, My CG is at 5 and 4 and 1/2 16ths (slightly over 5 and 1/4 inches) from leading edge. Mine flies fine at that CG. I have a book entitled "Aerobatics for Everyone" by Dave Patrick and he talks about Torque rolling with the Goldberg Sukhoi and he sets his CG at 6" from leading edge for best torque rolls[X(]! He also states "This setup isn't for the faint hearted so DON'T start here. We are near the point if inherent stability." Looking at my notes, I maidened mine at a CG of 4 and 14/16ths. After flying quite a few flights, I finally settled on about 5 and 1/4" (which is the furthest plans recommended aft setting) as stated above. I hope this helps as I would have to go into my attic and search for the plans to verify my notes.
#46
NC
Bass1, thanks a BUNCH! It's close to good flying weather here in NC (plenty of much-needed rain here in drought-ridden southeast), and I hope to have this plane covered and ready to go in a few more days. I've read so many threads on this plane's flight characteristics that I feel like I've already flown it!
