1/4 GP Wagstaff CA Failure!!!!!!!!!
VA
Just did the inspect on a newly acquired 1/4 G.P. Wagstaff and found the two lower ca hinges seperated on the rudder.
Didn't like this find at all!
Question is being new to the hobby:
1. Use Robart hinge point to replace ( will leave larger gap, and use new area to locate them in)?
2. Use pinned hinged Metal Dubro ( Will leave larger gap, and also relocate)?
3. Suggestions on repairs.
Before I proceeded, I felt that I needed more information and input before tackling this task.
I plan on replacing ALL CA HINGES!!!! this kind of failure is not what I want to experience while in the air.
Any suggestions and all help would be appreciated.
RE: 1/4 GP Wagstaff CA Failure!!!!!!!!!
correctly installed robart or dubro pinned hinges leave no gap.check the classic pattern forum under bpa hinges and look at the gap[none] of the cold duck stab/elevator
Most guys who fly giant scale airplanes won't use CA hinges. They just don't hold up to all the vibration.
Use Robarts. Countersink the heads with a cone shaped dremel bit. Seal the gaps with tape or monokote when you're done.
