what oil to use for smoke??
im using an os46FX (im not using a pump' im using the engines pressure) what should i use for the smoke fluid??
and is there any way of making colored smoke?
Assaf
Assaf
Here's my favorite smoke oil:
http://www.aircapitalhobbies.com/
As far as colors go, I don't know of anyone that has had much success using a muffler-type system.
My Feedback: (16)
John,
Isn't that the oil lamp stuff you (or maybe it was someone else) showed a pic of in one of the other "smoke oil" threads?
If so, you can get it at any Craft stores. I have a bottle that I'm going to test along with Super Dri.
I already tried PowerMaster smoke oil. Although I didn't do any adjustments, it did not impress me. Plus, it STUNK! Super Dri is odorless.
I plan to try Minn's stuff too.
Mike
Mike
My Feedback: (38)
http://www.rcuniverse.com/showthread...e&pagenumber=4
I use 99% pure liquid paraffin that I get from the local restaurant supply store (it is used in the floating restaurant candles). Cost is a miserly $7.00 a gallon! It is totally clear and it burns real clean and dry!!
My Feedback: (16)
Go to a craft store and get Lamp Oil. Don't worry about it saying, "smokeless". If you read further, it says don't get it too hot or it will smoke.
Mike
Mike
