Y Harness or Channel Mixing
CA
I have a JR 7202 and I am building a Skybolt ARF. What is the usual preference when using two Aileron Servos. A "Y" harness or channel mixing?
Any input greatly appreciated
Joe
Joe
RE: Y Harness or Channel Mixing
Here is almost the exact same question over at the beginners forum that will probably answer your question.
http://www.rcuniverse.com/forum/m_7115219/tm.htm
Austin
Austin
ORIGINAL: Ironhands
Joe
Joe
If I was you I would put each in a seperate channel. It really can't hurt anything and if you want to do some mixing down the road then you have the option.
Austin
Austin
Personally, I use a "Y" cord whenever possible - Why complicate things?
It's no harder to set up - so what if you have to adjust linkages? The nice thing is, if you ever switch radios, it's ready to go. There's no need to reprogram anything.
And with a Skybolt, you're certainly not going to use flaps or flapperons.
Keep it simple.
Keep it simple.
