Bending oleo struts
ON,
Bending oleo struts
Hi, I just maidened a FW190 today and after two smooth landings and subsequent taxiing the one gear leg has bent pretty bad. The retract units and struts are spring air and are 3/8" dia. The plane is a .60 size, 65" ws and weighs about 10.5 lbs. These gear have the scale 74 degree retraction angle and they are long at 7". What can i do to keep these from bending so easily, they are expensive!
thanks,
thanks,
ON,
RE: Bending oleo struts
figured []. Is there anything else i could do in the meantime? I was thinking putting a solid wire inside or a sleeve to fit over the outside of the strut to try to strengthen it. The retracts are bored for 3/8", so how would I fit a 7/16 strut in?
Bore the retract hole to 7/16". If you do not have a drill press, take the retracts out of the plane and bring them to a machine shop and have the hole enlarged.
I suggest having the hole bored to 29/64" to allow easier insertion of the strut.
