What kind of oil to mix for use in CRRC 26cc
Just like the title says, I have a CRRC GF26i motor, plane is ready, the manual says 2 cycle engine oil to break in but I heard penzoil will do just fine..Just curious what would work best/what kind specifically? THanks.
My Feedback: (7)
RE: What kind of oil to mix for use in CRRC 26cc
ORIGINAL: pilot511
On my CRRC 26, I use the same oil as for my 2 stroke lawn tools, just a little more% for break in. It's a sweet engine.
Follow the manuf. mix rate on break-in. Without their recommendation 1:40 of any good two cycle oil should be fine. You do not want to use marine outboard 2 cycle oil! Aircooled engine type only. Good luck.
.75 fl oz oil to 32 fl oz gasoline (3 oz to the MEASURED gallon) (43 ml oil to 1000 ml of gasoline) is my personal recipe yeilds 1:42.7 ratio.
Inspect your plug for idea of not only the fuel mix but the carb adjustments.
