BYRON AT-6 CG
BYRON AT-6 CG
Hi everyone, i have a BYRON AT-6 TEXAN of Byron, i bought this plane few months ago, but i don´t have the USER MANUAL, BOOKLET or PLANS, and
i have to check the CG, can anyone help me !!!
Regards
Al leal
Regards
Al leal
RE: BYRON AT-6 CG
Measure the model with a yardstick. It's easy. 9 measurements and easy to do.
Plug them into this online application, and tell it to use 20% for the static margin. Read out the location for that margin for the CG. Change the 20% to 5% and run the application again. Read out that location for the CG. You've now got the CG range for the model. If you are not an experienced flyer, then use 15% and 10% for the range.
http://www.geistware.com/rcmodeling/cg_super_calc.htm
