Beeping motor
Old 08-26-2008, 09:23 PM
vicman
My Feedback: (10)
vicman's Avatar
Default Beeping motor
A week or two ago there was a thread about electric motor just beeping. I didn't look at it because I had not had that problem myself but it happened last night. Now I can't seem to find it. Can someone point me in the right direction please?
I'm putting togeather a World models Voodo that comes with the motor. When I hook everything up to test it out the motor just beeps and doesn't turn.
Thanks for your help.
Vic
Old 08-26-2008, 09:39 PM
ChuckW
ChuckW's Avatar
Default RE: Beeping motor
It sounds like the ESC is trying to tell you something. The ESC instructions should tell you. This is just a guess but maybe the ESC thinks it is being powered up at full throttle and therefore not letting the motor go. Try reversing the throttle on your transmitter then following the arming procedure in the ESC instructions. Many have to be powered up at no throttle, pushed to full then pulled back again before it will arm.
Make sure you do all of this without a prop on the motor. In spite of knowing better, I figured this out the hard way.
Old 08-27-2008, 06:18 AM
kid chuckles
I have had to do this also. Move the throttle stick very slowly up and there will be several beeps. Sounds like the reciever is not binding with the ESC. Or the motor part of it anyway. Just move it slowly it took a couple times on one motor to get it to respond to the reciever. Hope this helps you out. You may have already knew this if so and it didn't work [&o]
Old 08-27-2008, 12:35 PM
vicman
My Feedback: (10)
vicman's Avatar
Thanks guys, I did reverse one wire to reverse the motor rotation but didn't try reversing the TX. When I get home I'll give it a try.
Just a test run with no prop...thanks for the safety notice though. They are important.
Old 08-27-2008, 02:45 PM
erik valdez
My Feedback: (80)
erik valdez's Avatar
can anyone tell me how to figure out what speed controller i have. i remember buying it a few years ago but ive lost paper work i know it is made by castle creations but how many amps? it is just a small board wraped in clear heat shrink. thanks erik.
Old 08-27-2008, 02:48 PM
vicman
My Feedback: (10)
vicman's Avatar
a picture might help
Old 08-27-2008, 03:18 PM
erik valdez
My Feedback: (80)
[img][/img]here are some pics
ID:	1020616   Click image for larger version
Old 08-27-2008, 03:35 PM
BadSplice
BadSplice's Avatar
I have one that looks like that, its a Castle Creations Pheonix-10.
Old 08-27-2008, 03:39 PM
erik valdez
My Feedback: (80)
I have been flying this esc on an e-flite ultimate bipe with a park 370 outrunner and 910 mil 3cell pack. i just bought a park 400 is this esc sufficiant?
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
