bending of brass pipe
RE: bending of brass pipe
I usually just bend them gently with my fingers so as not to crimp them. Sometimes I run a wire, something about the thickness of a throttle cable, through it prior to bending.
MN
Spend the $10, well worth it. Works Great on Brass, but sometimes aluminum will split.
http://www3.towerhobbies.com/cgi-bin...?&I=LXE228&P=7
PA
ORIGINAL: nothinbetr2do
+1 on the sand, i use playground grade sand
Stealing sand from kids to support your r/c addiction!!!!...............You should be ashamed of yourself!!!! [sm=48_48.gif]
....j/k,lol
I use the back side of a drill bit that just fits in the tube, bend a little, then move the bit out, and bend a little, and move the bit out...etc etc..
that way I am not waiting for water to freeze or soften the brass by heating it and my work table is a big enough mess with out throwing sand on it.. lol
Good Flyin
Good Flyin
MD
ORIGINAL: Jester241
....j/k,lol
....j/k,lol
NJ
The K&S Spring Bender works great. If you aren't placing a Tower order soon, they are available at Ace Hardware.
DaveB
http://www3.towerhobbies.com/cgi-bin...?&I=LXR791&P=7
DaveB
