Reload this Page >
Pusher motor question
Old 08-27-2008, 06:17 PM
NvMike
Default Pusher motor question
I have an OS 40 LA, 10x4 prop, on a BUHOR frame and a Rogallo (kite) canopy. I would like to modify it and make it a pusher. Can an OS 40 LA be run backwards so I can use the same prop? Or should I just buy a pusher prop?
Old 08-27-2008, 06:34 PM
BillS
Default RE: Pusher motor question
If the front housing is not removable the engine cannot easily be run backwards. Pusher props are not generally available at the Hobby Shop. However APC pusher props are made in 10 x 6, 10 x 7, and 10 x 8. You might make sure pusher props can be found in sizes you are planning to run.
Bill
Old 08-27-2008, 08:10 PM
NvMike
Thanks Bill
I will check out the pusher props before I do the build.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
