2 Rx batteries ?
FL
2 Rx batteries ?
Gentlemen,
I have a 4.8v 2000 mAh 4 cell nMhi battery
and a 4.8v 700 mAh 4cell niCd battery.
From what I have read here in the Search area, as long as
both batteries have the same number of Cells it is ok to use both
together. But, can I mix different chemical properties ?
(niCd's and nMhi )
I am using 2 switches harnesses also, plugged into seperate
Channels on the Rx.
The plane is a GP 40 Stik and a Futaba 6ch. 2.4 Tx & Rx
with 6 servos. Running a Saito 82a .
Thanks for your input,
Bob
My Feedback: (16)
SC
RE: 2 Rx batteries ?
I agree. I wouldn't put two batteries in that plane. Not worth the effort. The 700mah batt is way more than enough alone. Where does the 6th servo go. The plane calls for five?
FL
Thanks, I took yall's advice and set my plane up with
just the 1 battery. I made it so I can replace the battery
with little effort, after the wing is removed. Still have the
2 Switch harnesses installed but using just one.
Bob
I have an old 8 channel Futaba that I use occasionally, it's at least 10 years old and didn't even give it a second thought, just always use 5 cells.
Ask the question on the Futaba support page.
NE
I believe the only servo's that Futaba has listed at 4.8volt only are high end digitals using nylon gears or special purpose, i.e. gyro. The F3A Futaba digitals I use are 4.8v only. But unless you plane on putting $100 digital F3A/Pattern servos in your 40 stick, don't worry about it. I'm not aware of any Futaba RX that is rated for 4.8V only. Use 5 cells if you want too. Be aware, you will not get as many flights from a 5 cell pack of the same size as a 4 cell pack.
FL
John,
Thats what I had heard (read) too. I have
4 Rx pacs all 4 cell, so i'll stay the course.
No I don't have $100 servos either lol.
Bob
