zenoah 26cc ei gas engine
My Feedback: (63)
IN
I just bought two zenoah 26cc ei gas engines and here is my problem . they run just fine but my radio go crasy , what do I need to do to fly these things - no one at the flying field can come up with a answer - we seperated wires and moved the parts away from the RX and even took them out of the plane and put them on the ground under the plane and still interfered with RX
HELP thanks
HELP thanks
My Feedback: (63)
IN
RE: zenoah 26cc ei gas engine
I found the problem to day and want to let every one know - THE PLUG WIRE WASN'T PUSHED ON FAR ENGOUGH ....... make sure the plug wire is pushed all the way on till it snaps , will never make that mistake again ............
PA
Cool!...And thanks for letting us know what was wrong and it wasnt somthing major. I was worried about it as I'm just new to gassers myself,and thats one less issue I need to be concerned about.
TX
All,
I was gonna say I have a Zen 26EI that runs great no RF and I noticed that Zenoah uses the same ignition cap as 3W along with the CM6 plug and I remermber 3W warning you to make sure the cap goes all the way down over the spark plug base and locks. Its hard to get back off and you dont want to pry it or twist it but no RF. Glad you found the problem. Great little engine isnt it !! wish it had a little more power but then if it did it wouldnt be such a sweetheart of a motor.
Good Luck
JDS
Good Luck
JDS
My Feedback: (-1)
I have never seen A loose plug cap do that, when my cap is loose my engines just won't start or they reu so ragged I have to shut them down and look for A problem. I have seen A lot of people forget and use A metal rod for the throttle and seen all the RF kicking servos around. I went over to the gas engine forum and found several threads on setting up A gasser that go into great detail about it.
Glad you found your problem and it was A simple one. I once changed my set up several times then found out I had A bad RX antenna, that took A while.
