determining cg
Old 09-12-2008, 11:09 PM
jjoos99
My Feedback: (12)
Default determining cg
I am putting together a plane that was found in a tree by a local farmer and need to balance it. I dont know what model it is to look it up. It is a sailplane similar to a gentle lady but has a .10 engine on it and the rudder is different. How do i determine what the cg point is on this plane?
Jeff
Old 09-13-2008, 06:25 AM
da Rock
Default RE: determining cg
http://www.geistware.com/rcmodeling/cg_super_calc.htm
This application is basically what's used in the aero industry. You need to do 9 measurements. And make a choice of what Static Margin you want. If you want a range for the CG, run the application twice, just changing the S.M. for each. Run it with 20% S.M. then with 10% and you'll have the CG range.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
