Charging NiMH batteries
My Feedback: (41)
I just bought a used plane and for the rx there is a NiMH battery. I have the stuff to charge it with (Trion Jr and adapter) but was curious as to which rate to charge it at. The battery is a 4.8V 2200mAh. The manual that came with the triton says to use a rate that would charge it 1-2 hours thats either 1.1 or 2.2A. Is it ok for these packs to charge that fast if not what is a good charge rate.
My Feedback: (14)
KS
RE: Charging NiMH batteries
I have been using Hobbico's Accucycle Elite for a few years now. I have several 4.8v 1650mAh packs and a few 6v 1700mAh, all NiMH. The charger is set at .65 amps for peak charging and .3 amps for trickle charging. These rates have been satisfactory for me. Hope this helps!
1 Post
The usual recomendation is 1/10C for charging then 1/100C for trickle.
In your case that is 220mah [ 14 hours from fully discharged ] and 22mah trickle.
They will last longer charged at these rates.
Since this is a battery that you do not know the history of (it may be old or abused) the first thing you should do it charge it for 16 hours at 0.1C and then do a discharge test by discharging at 0.2 to 0.25C down to 0.9 volts/cell and measure the capacity. If it is about 80% of the stated capacity, it is probably safe to use; i.e. won't cause your system to fail. Also, on NiMh is not recommended to do a trickle charge as that will shorten the lifespan of NiMh. Contrary to much of the comments here in the forums, NiCad batteries still rule over NiMh in all respects except mass per unit of energy. If you can stand the slightly increased weight, you will get twice the life and more immunity from minor abuse such as overcharge and trickle charging by using NiCad versus NiMh.
My Feedback: (41)
I have a Triton Jr charger and the manual states 1.1A-2.2A for a 2200mAh battery is that way to much I would like to be able to charge in at least 4 hours or would that put the pack at too much of a risk. Im thinking of just gettinga NiCd for it since I feel more comfortable with them and they are more tough.
Hi!
As has been said before. NiMH cells doesn't like to be fast charged in the long run. It can be done but don't expect them to be too long lived.
Then there is the problem with "False Peak detecting" All fast chargers use Delta peak charging and NiMH cells often false peak when you fast charge them. It's therefore wise to slow charge them with 0.1C (in your case 220mAh) now and then and don't rely on the alarm signal the charger puts of when the fast charging stops. The battery pack isn't always fully charged.
the thing with the triton jr. is that it has a time limit of 90 min. so you can't charge your battery in 0.1C. I'm using Ni-Mh batteries too. I usally charge them with 0.4C. But as Rodney said Ni-Cd is always a better choice
ohhh I didn't know that. I'm using a triton II rigth now.
As an answer to yout question: in my opinion you don't have to charge your ni-mh batteries with 0.1C. I am charging my 2200 mah ni-mh with 1amps and using that battery for about 1.5 years now. It still can hold 2200 mah so there is no problem.
My Feedback: (41)
Thats good to here. The thing is my triton jr only has a 12v input and I dont want to have to leave it on my car battery that long and dont rally want to purchase an 80 dollar power supply. Ive been looking at getting the Accu Cycle elite since it has ac and dc input.
I wouldn't do that. you can buy a simple power supply. like : http://www3.towerhobbies.com/cgi-bin...&I=LXRJN7&P=ML
or you can buy a computer power supply (the atx ones which has an on-off switch) and use it. This way it is cheaper. A 150-200 watt power supply is enough for your triton jr. That's what I'm doing for years.
