Reload this Page >
Retract Servo??
Retract Servo??
Old 09-16-2008, 03:53 AM
greigmckean1
Default Retract Servo??
Can you use a standard servo as a retract servo? Or does it have to be a designated retract servo?
Old 09-16-2008, 06:16 AM
DavidAgar
My Feedback: (107)
DavidAgar's Avatar
Default RE: Retract Servo??
It is best to use a retract servo. They have more torque and they shut off at the end of each cycle. They also have more throw than a regular servo, which is what you will need to make the gear retract correctly. Good Luck, Dave
Old 09-16-2008, 10:23 PM
sebo
If you use a regular servo you will drain your battery so fast that you may be lucky to get only one flight in.....ask me how I know.
Old 09-16-2008, 11:51 PM
greigmckean1
Im using it for an electric setup so would I get away with it because I will be using a fresh battery for each flight anyway? Can you get micro retract servos?
Old 09-17-2008, 01:43 AM
sebo
I don't know anything about micro stuff. Sorry.
Sebo
Old 09-17-2008, 01:49 AM
sebo
Listen to what David Agar says. He is absolutely correct. Use a retract servo for retracts.
It just may save you an aircraft.
You may be inviting problems.
A servo is less expensive than a plane.
Have you ever seen one fly away after it was airborn?
Fascinating!!!
sebo
Old 09-17-2008, 04:49 AM
Don M.
Don M.'s Avatar
I'm going to go completely against the grain here. Years ago I had a GP F-14 Tomcat and used 2 Futaba 9202 servos for the retracts ( 2 on 1 servo and 1 on the other ) I flew it 100's of flights and am still using those servos somewhere. I just happen to be building another F-14 as we speak and yup I'm using 2 regular HT servos. Just make sure they don't bind.
My reason for using them was not to be cheap but because the throw of the standard servos suited my application much better.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
