WHICH PLYWOOD???
GA
WHICH PLYWOOD???
I am working on my first scratch build its a 46 size nitro ducted fan delta. I plan on making the duted fan formers/wing joiner spars from 1/8 plywood. Should I use Midwest aircraft plywood or is the lite ply okay. Their is a very big price differance.
1 Post
RE: WHICH PLYWOOD???
Depends on the strength you need.
Personally I use lite ply coz light models fly better. Seriously avoid anything that adds weight unless you really need the strength eg U/C mounts.
could always go this route too if you needed stronger formers instead of lite ply http://www.airfieldmodels.com/inform...wood/index.htm
