Ailerons on a Kadet Sr.
IA
I am re-building a Sr. wing, reducing the dihedral to one inch at each wing tip, and installing barn door ailerons. My question is: how many rib bays should I use for the ailerons? My Kadet Sr ARF uses 7 bays, I would like to use only 6, will this be enough?
