Bed Slide
Moderator
RE: Bed Slide
Plenty of people have. A simple one would be a plywood slide with PVC racks attached. There are lots of threads on the forum with pics of the racks.
MN
RE: Bed Slide
A guy at our club built a very nice one this past year, it even has ball bearing rolling guides. He is a true woodworker and does beautiful stuff, I'll see if I can find a picture.
RE: Bed Slide
I currently use a sheet of 3/4" ply cut to fit between the wheel wells and just long enough to get snug when the tail gate is up. I have large eye hooks set into it at regular intervals and use bungees over the landing gear to hold the fuselages in place, and a PVC rack for the wings. I have to lift the wood about 10-12" before sliding it, but it's not too bad. I would like something sturdier on rails, but this was quick and cheap for now.
FL
RE: Bed Slide
ORIGINAL: daven
I would also be interested in his design,
Bob
RE: Bed Slide
I used to race r/c cars with a guy who had a slide made from aluminum extrusions used in the manufacture of floating docks. It had a set of folding legs on the front and he said it was mounted to a set of extra HD drawer slides. Even loaded with gear it was a single handed pull to get it out of the truck and the legs had short adjustable sections on the bottom to keep it level and fully supported on uneven ground. It took him longer to put up his EZ up than it did to have all his gear out of the truck and ready to use. I thought it was way cool for racing, but it turned out the guy was also a flyer and built it for his planes. He just dismounted the wing racks when he went car racing.
