Any reviews of Tenergy batter packs?
MI
I was looking at a Tenergy batter pack for my next receiver battery purchase (6V 2300mAh NiMH RX Receiver Battery Pack). They are listed on eBay.
Does anyone have any experience with these batteries? Good or bad?
FL
RE: Any reviews of Tenergy batter packs?
I've used these... So far after 1 flight season they are still goiing strong. Nothing bad to say about them. I have also used some of their lipo packs for my electrics and find those to be of good quality as well.
My Feedback: (8)
I used one all summer long. Was able to fly for days without a recharge. I then got a Hobbico Hydrimax battery and noticed the Hydrimax seemed to have a lot more 'life' to it - faster, stronger responses. I put the T-energy battery in a plane with ONE digital servo, and the Voltwatch goes from highest green to lowest red with ANY stick input. This is on a plane with a brand new switch and no servo extensions (happens when wings are off, too, so only 3 servos operating). This leads me to believe that the batteries are NOT rated for high current draw. They might be OK for use with standard analog servos but I would NOT suggest them for anything else.
MI
ORIGINAL: gaRCfield
WI
I've been using a 2000 mah 6.0 V NiMh pack in both my Twist 40 with standard analogs, and in my Showtime 90 with Hitec 5645 digitals. I've had both of these planes flying for over two years with hundreds of flights and no issues at all. I check the voltage before every flight, but that's a habit that I'd do no matter what kind of battery pack.
Btw, I purchased mine from www.all-battery.com/rcairplanebatteries.aspx
My Feedback: (8)
ORIGINAL: starfire73
How do your non-Tenergy batteries perform using the voltwatch, with a stick input?
ORIGINAL: gaRCfield
Checking the voltage between flights would do absolutely nothing to identify this problem. The battery is at full voltage but does not release sufficient amount of energy on demand. This is VERY DANGEROUS for those of you flying with the receivers that 'reboot' with low voltage spikes. Maybe not such a problem with 6volt battery, but maybe it is if the voltage is dropping that much.
MI
I'm wondering... is there any way to measure a battery's capacity to supply power under load? Do batteries have a rating you can check to see how it efficient it is at supplying power when drawn?
This is the load meter that I use. I like it much better than an expanded scale voltmeter.
http://www.horizonhobby.com/Products...?ProdID=HAN171
Cheers! BH
Cheers! BH
Hey GaRCfield,
Are the Hydramax and Tenergy batteries the same size? Like 2/3A, or AA, or whatever? I am curious about this and would like to know what the composition of the pack s is (what are the cell types and model numbers). I think if we had the info on the cells, then impedance could be determined and then current capacity would be spelled out.
Curtis
P.S. How is school going?
Curtis
My Feedback: (8)
ORIGINAL: beau0090_99
Hey GaRCfield,
Curtis
Hey GaRCfield,
Curtis
I was using the T-energy all summer with analog servos and didn't notice any problems, but when I got the Hydrimax and plugged it in, the servos seemed twice as fast and twice as strong, even when both batteries were fully charged. The difference is enough to make me clear my bench of my current project and grab my 'backup-backup' plane and rip the Tenergy out from under the fuel tank and stash it for benchtop use only. I am disgusted that I ever flew my new 2.4ghz system with that battery.
School is good; heat transfer is a bit tough but I like it. I liked fluids so much last semester that I decided I will apply for a master's degree here in Fluid Mechanics if I don't end up in Aerospace somewhere else. After all this battery talk (and speaker talk with my roommate) I'm now looking forward to my 2 EE classes and my electromagnetism class. Thanks for asking!
That's cool.
Wow, I am surprised that there is that much difference between the packs. I wonder what the MFG specs on impedance are between the two types.
Glad school is going well, I had the opposite experience, I loved Heat Transfer and Thermo, but hated Fluids. To each, his own.
Curtis
Curtis
There have been VAST discussions on the merits and pitfalls of Tenergy packs over on the car section of the forum. I have not used them myself, but have seen user feedback ranging from "susprisingly good for the money" to "run away quickly". IIRC, the higher capacity rated cells fell down when compared to other brands of similar capacity but the middle range sub-C (3500mah) packs were well-liked. To be honest, I haven't seen a lot about the 2/3A or AA ells. The 130mah lipo cells seem to be working out as a replacement for the parkzone and e-flite micros.
TX
ORIGINAL: gaRCfield
[/quote]
LOL, JK.
My Feedback: (7)
I bought 32 of the AA 2300mah NiMh cells from All-Battery.com. I must tell you that these batteries are the worst I have ever owned. They show to take a full charge but go dead VERY quickly. No actual numbers but my Energizers of the same type last easily 3-4 times longer in whatever I am using them for.
VERY DISAPPOINTED. That goes for all 32 cells. Not one good one in the whole lot. Stay Away.
