Magnum120 4S
PA
Magnum120 4S
Having much trouble getting my Mag 120 4S to draw fuel from the tank. The fill line to the tank is connected to the carb and I can push fuel out of the tank by blowing in the vent line. The carb is also clear where fuel will easly flow thur it. The engine is mounted upright on a test stand.
I can get the engine to fire up ( on the first flip no less) if I squirt some fuel into the carb but it will only burn the prime and not draw any fuel from the tank.I tried to openup the low speed needle but still no luck. Any ideas ? Phil
ON, CANADA
RE: Magnum120 4S
Try removing the high speed needle and blow some fuel through it to clean it out, then try the same thing with the low speed. If that doesn't work pull the carb off and soak it in fuel for a couple days
PA
RE: Magnum120 4S
Thanks guys for your replys. It turned out the factory low speed needle valve was set wrong at the factory. I reset it to the factory specs and everything is a ok.
