gas in glow fuel jugs
RE: gas in glow fuel jugs
It is a very dangerous thing to put gasoline in any container not marked as such; not because it will damage the container but because of the possible bad side effects if someone mistakes the real contents of that container. In some states it is against the law to put gasoline in any container not labeled as to contents.
My Feedback: (68)
ORIGINAL: w8ye
Well, it is illegal in some areas and someone may make an issue of it? Some gasoline service station will refuse selling you gas to fill your plastic jug.
Keep in mind that the translucent glow fuel jug will let sunlight in which will degrade the gas faster than if it was stored in a red or all metal container. Though this is a slow process and you will probably be using the fuel fast enough for this to not be a problem.
My Feedback: (-1)
No sun problems and the price is right!! I always try to buy products with the big cap on the cans so i can make up vents and drain and fill systems. I have even been known to paint them red a couple of times. Wish I could find them in two gallown though, seems it's either 1 or 5.
