Vent line in tank
Vent line in tank
Does the brass tube that is used as a vent line in a typical tank have to be bent to 90 degrees? Ibent mine to about 60 degrees andit stopsjust short of the top of thetankwhich is what it is supposed to do, but someone told me the tube has to go straight up and hence has to be at a 90 degree angle.
The tank is already installed in a 4* Sixty that Iamfinishing and it would be some work to take it out.Is it necessary to do so, or is the current set up going to work?
CT
RE: Vent line in tank
Mine is set at about 60 deg also. If it is up to the top of the tank than that iswhere it sould be. There is no need to bend it to 90.
NY
I am no perfectionist and if memory serves me correctly, NONE of my planes, or helis, have a 90 degree bend in the vent line!
I bend the vent line to the greatest angle possible, which will allow inatallation of the completed stopper assembly AND which locates the vent tube at the top of the tank.
Deburr all the brass tubes inside and outside then clean thoroughly. Lube the rubber stopper a bit, and you shoud be good to go.
IF...you must do a 90 degree bend, take a round (jewler's) file and make a profound groove on the vent tube's inner tank end, to prevent severing tank venting via a flat end of the tubing making contact with the tank.
Good luck!
Good luck!
you could have the vent tube stuck straight out if you wanted...but then you'd only get a 1/2 of a tank of fuel.....near the top so you get a full tank..no need for 90 deg
My Feedback: (18)
I stopped using tanks with brass tubes and stoppers years ago, have gone strictly to Hayes tanks, very easy to asemble and never leak. No stopper toget brittle no tues to crack. Rarely use tanks that come withARF's, withmodify plane to make the Hayes fit first.
Another trick to use on the vent, keep is short then add a short length of fuel line to the end to extend it to the top of the tank. Cut a small V shape in the upper end so that it can not be restricted by touching the top of the tank.
My Feedback: (-1)
ORIGINAL: Rodney
