gyro on a plane
NJ
gyro on a plane
just got a 401 gyro from a guy, (free), what would happen if it was put on a plane and where would it go rudder ? maybe......and if so what would it do as to flying the plane
RE: gyro on a plane
Rudder.A gyro will help on a twin or conventional gear design and even a heavy warbird type as it will help to slow any snap roll or ground looping.not really needed on a sport or trainer type plane
My Feedback: (-1)
RE: gyro on a plane
Used one on a Fleet Bipe on rudder with very bad ground handling problems, it was fine for take off but tended to fight for control in the air. Ended up putting it into ch 5 so it could be turned off after take off. Don't bother with one unless you really need it, I just got used to the plane and made my life easier.
RE: gyro on a plane
Some use it on the ailerons for flying in heavy winds to keep the plane level kind of a self righting thing. Oh and they are going for $75shipped on the heli websites. But if you dont know how to set one up properly it will do more damage to you than good. I use the cheaper futaba gy240's on my heli's they are simpler but I can see little advantage of using one on a plane the tail on a plane doesn't have any huge counter rotation forces to deal with like the other guy said you are better off just learning to fly the plane or maybe feed in some expo or half rates depending on the problem.
RE: gyro on a plane
OK Barracuda maybe self righting was the wrong terminology it will help hold a position and dumb down the sensitivity relative to how much gain is set on the device. Better?
As for the gyro cost here is a link http://www.runryder.com/search.htm?d...ortby=lastpost But be quick they are sold all the time for $75 one went for seventy.
