Futaba T6XA manual?
Moderator
RE: Futaba T6XA manual?
Very similar radios between the T6XA and 6XAH. The T6XA doesn't have exponential, but nearly everything else is the same. I have the T6XA if you have any questions.
NE
Thankyou, I have downloaded the Manual. The radio appears to have a few more uses than my 6EXAP that I already own The analog trims are easy to adjust when trimming, but easy to bump and throw out of trim. I'll be needing some receivers and crystals on low band. I own a 2.4 radio but also have not ever had any trouble with FM that was not my own fault. Once again, Thanks for your help.
My Feedback: (20)
GA
ORIGINAL: ricktrcu
I'm looking for a copy of the T6XA radio owners manual too.
Where did you find it on line?
The link to the manual is great , it help refresh my brain to do the sttings after 7 years relaying all my "toys" in the storage and the manual was gone.
Thanks Ken for giving the link
