FUTABA 6EX-2.4
CA
FUTABA 6EX-2.4
WHEN ALERON CONTROL IS APPLIED OR RELEASED THE SERVO WILL OSCILLATE AROUND CENTER THEN STOP. I HAVE TRIED A NEW SERVO AND GET SAME RESULTS. ALL OTHER CHANNELS WORK FINE. I HAVE FLOWN THE PLANE ONE TIME, BUT NO MORE UNTILL I GET IT FIXED. WHAT COULD BE THE PROBLEM?
CA
RE: FUTABA 6EX-2.4
you probably need a new aileron pot. if it is under warranty, it wil be a free fix. the pots on these radios are not the best quality. I have had 2 of my radios like this throttle pots go out, they did the same thing
