1st place engine sig 1.3 parts
different engines use different sized adapters ...you didn't mention the engine or the size of the spinner, different spinners use different bolts....
Here is the first page of Dave Brown alum spinners and page after page of adapters at Tower and as Jetmech said everything depends on what engine you are using.
Also you can find an even larger selection of Adapters at True Turn just search it and you will find much more and many can be use with the DB spinners.
http://www3.towerhobbies.com/cgi-bin...=RF&search3=Go
John
John
thanks put engine size in subject header,not to smart but it is the small gas 1.3 first place by sig,going to call them not sure they sell db products thanks for the link, strange engine hub it has a female instead of a treaded shaft frank
