Circle Cutters for MonoKote/UltraKote
My Feedback: (10)
I want to cut some Roundels for a Warbird, has anyone used or what recommendations for a decent Circle Cutting Tool that works on MonoKote/UltraKote or other Heat Shrink Covering; I was looking at one made by 'Fiskars' pictured below.
Thanks.
Thanks.
My Feedback: (10)
RE: Circle Cutters for MonoKote/UltraKote
Yes I thought of that, and tried it as well, the problem was that it leaves a hole in the center; not very big, but a hole all the same; I may go this route and save the expense of buying a fancy Circle cutting device; I was hoping to hear from others as to what they use, to give me some ideas, that's the beauty of RCU, you get some great ideas and feedback.
OK
I use a LARGE compass I got from MicroMark with an x-acto blade. Workes fine for me.
As to the hole in the center here is what I did to fix that. Taped a small square of thin
ply to the monokote for the compass point. Puts the hole in the ply - not the monokote.
My .05 on this.
Dan
My .05 on this.
Dan
IN
BRILLIANT!! You learn something new everyday! I always just ironed on a tiny patch of scrap covering over the little hole I had made.
The Hobbico Circle Cutter http://www.hobbico.com/tools/hcar0230.html costs about 6 bucks. You still have the 'hole' to deal with but the suggestion of taping a piece of thin plywood in the center is a really good solution.
I have always just traced circles and then cut them out with scissors. This was with the peel and stick trim sheets, though, and not regular film.
And, yes, I probably spent more time decorating this plane than I ever spent flying it.
And what ironing "techniques" did you guys use to achieve a bubble-less application? I use Ultracote. How about Monokote over Ultracote? Ultracote over Monokote? Enquiring minds (usually get me in trouble) ...
For Monokote over anything I use Windex. Just spray it on the surface, apply the Monokote to the wet surface, and smooth out all the bubbles. Let it dry overnight, and it's usually pretty solid. A little clear nail polish on the edges can help as well.
If you use a generic window cleaner, make sure it has ammonia in it. I once tried this method with "Glass Plus", and all my decals fell off the next day. The Monokote adhesive is activated by ammonia.
I've never trimmed with Ultracote. I prefer it for covering, but I always use Mono for any multi-layer designs, just because it can be applied with the Windex.
The plane I posted above was just self-adhesive Monokote trim sheets, so this didn't apply in that case.
Good luck
Good luck
If your name was Cliff I would call you Cliff. [:@]
Do you fully shrink the Ultracote before you apply the trim? I've noticed that when Ultracote is initially applied with a fairly slow iron the surface has a marbled texture. After applying a fast iron or heat gun the surface attains a mirror-like surface. I've gotta guess that you apply the trim after shrinking.
tia for sharing your experiences!
ORIGINAL: mclina
For Monokote over anything I useWindex. Just spray it on the surface, apply the Monokote to the wetsurface, and smooth out all the bubbles. Let it dry overnight, and it'susually pretty solid. A little clear nail polish on the edges can helpas well.
If you use a generic window cleaner, make sure it hasammonia in it. I once tried this method with "Glass Plus", and all mydecals fell off the next day. The Monokote adhesive is activated byammonia.
I've never trimmed with Ultracote. I prefer it forcovering, but I always use Mono for any multi-layer designs, justbecause it can be applied with the Windex.
Beware of using ammonia based window cleaner to attach monokote to monokote. You have to seal the edges or activate the glue with low heat. Ammonia has no effect on monokotes adhesive. I ruined a covering job just using Windex. Lost graphics in flight and had to start over with an oily airframe. I have stored scraps of monokote for 2 years in a jar of Windex on my bench and it has no effect on the adhesive what so ever.
I've used monokote extensively for trim, and I wouldn't consider an alternative to Windex.
Here's a tip for sealing the edges so that you'll never have to worry about the trim coming loose. No less than 24 hours after applying the MonoKote trim with Windex, apply a thin film of Top Flite Trim Solvent along the edge of the trim with a small paint brush. The Trim Solvent dries clear without any visible residue. I did this on my GP Super Skybolt six years - and many many flights and some rough treatment - and the trim never came loose. Forget about fingernail polish; it leaves an ugly residue and it won't last.
If you really want to make a dazzling livery scheme, use thin strips of MonoKote of a color that contrasts between the two colors. On my Skybolt, I used 1/8" wide Insignia Blue strips at the edge of the trim, creating a border between the red and the white.
Mike
Mike
ORIGINAL: mirwin
If you really want to make a dazzling livery scheme, use thin strips of MonoKote of a color that contrasts between the two colors. On my Skybolt, I used 1/8'' wide Insignia Blue strips at the edge of the trim, creating a border between the red and the white.
Mike
Mike
I forgot one other thing: paint those props! After balancing the prop, I use Rustoleum gray primer, fine steel wool to smooth it out, and then Rustoleum spray cans. Put a little glob of extra paint at the prop tip to rebalance if necessary after painting. use the same thin strips of contrasting colors between the colors that you apply to your prop.
Mike
mirwin - nice detail. I'm still at the stage that focuses on function. Tryin' to get it right so that it'll fly well. Initially I focused on form before I had a clue about function. You obviously have both. Thanks for sharing.
