OS 120 III 4 stroke W/pump
My Feedback: (20)
RE: OS 120 III 4 stroke W/pump
As I suspect you know, the instructions say the starter is required. I have never tried to start it by hand. Mine requires a lot of cranking with the starter to get it going when cold. Starts quickly hot, or after having been run. You might be able to start it by hand if you could access the carb and prime it.
