3 blade prop for OS 52 FS
I'm about to launch into building a Dornier 335, 66" span and intend using an OS .70 FS up front and .52 FS out the back.
The OS manual for the .70 gives a suitable size for a 3 blade prop, and that's 11 X 7.
The .52 manual nominates 11 X 7-8, 12 X 6 and 12.5 X 6 as suitable in 2 blade props, but no recommendation for a 3 blade. I'm thinking 9 X 7 pusher would be OK. The range of sizes in pushers is limited, and even more so in 3 blade.
Does anybody have any thoughts, or experience on a 3 blade with an OS 52 FS??
Banned
RE: 3 blade prop for OS 52 FS
ORIGINAL: Semi Retired Aviator
I'm about to launch into building a Dornier 335, 66'' span and intend using an OS .70 FS up front and .52 FS out the back.
The 11x7 Master Airscrew will work fine for your O.S. engine. I'm running a 10x7 on my Super Tigger .51 and it works just fine for that engine. I tried a 3-blade Master Airscrew 14x7 on my O.S. 91FX- Ringed and that engine loved it. I also run a Tru-Turn Spinner and adapter with all of them ranging from a 2"- 2-3/4".
You're good!
Pete
