Easy question 4.0v and 6.0v how low?
FL
My question is on a 4.8v how low can I got to discharge? The same question for the 6.0v. For 6.0 what's the lowest safetly flying I can do when my batterie is low?
FL
RE: Easy question 4.0v and 6.0v how low?
Ahhh? Example if my 6.0v 2450mah battery shows at the digital voltimer 6.28 that's good? How low can I go ? 6.0v? What is supoust to show when is fully charge? 6.78?
does your digital voltmeter apply a load to the battery? If not don't use it because it only gives you the voltage in a no load condion....as soon as you apply a load such as turning on the airplane the voltage can drop.....alot of airplanes have been lost checking battery voltage with a standard voltmeter
