RCM Trainer control surface throws?
WI
I've come across an old RCM Trainer 60 that is in good shape and I'd like to get it flying again. Does anyone have the throws for the ailerons, elevator & rudder as per the plans?
Birman
Birman
WI
RE: RCM Trainer control surface throws?
Bax, I sent the email to [email protected] as you suggested, and here's the reply I received.
"Thank you for your recent email. I am sorry but we do not have the manuals for the Global planes. You would need to contact them. I have included their information below."
Birman
Birman
If it's the old Bridi trainer, I fly one alot.
I have MUCH throws on both ail,rudder and elevaitor.
But I fly it like an old pattern bird.
The Bridi trainer does not behave bad in any way if you use big throws.
Good luck
Good luck
Not what you need, but there is a reference to the construction article:
http://www.rcmplans.com/index.php?ma...eyword=trainer
