Spinners for 3 blades props
My Feedback: (-1)
RE: Spinners for 3 blades props
Being in another country how do you go about ordering items like this or is there a hobby shop that orders things for you?? For three blade spinners I have found it best to just call true turn and order the spinner cut for the prop size I'm going to use. When they say standard those slots never seem to fit my props at all. It's just easier then cutting them myself.
My Feedback: (10)
OR
You might want to try;
AFP Procon S.R.L.
Andrei Petre str. Sperantei nr. 22, sect.2
2099 3 Bucuresti
Sierra Modellsport SRL
Corneliu Avasilichioaiei str. 1 Decembrie nr. 21
70100 0 Botosani, Romania
Or even;
http://www.neuershop.jamara.com/index.php?s=3&lang=eng
AFP Procon S.R.L.
2099 3 Bucuresti
Or even;
1 Post
ORIGINAL: Gray Beard
One of my LHS started stocking spinners under the Magnum name, I started using them over a year ago and really like them. Very good price too.
As usual I agree with Gray Beard. They are marketed here in Oz as Magnum also.
Cheers,
Colin
Colin, can you get them in 3 bladed in this country, all the places I have tried say, magumn only come in two bladed spinners. Im after a 4" (100mm) 3 bladed spinner.
Cheers
Cheers
My Feedback: (-1)
I have never seen a Magnum in three blade. I have had to order them from Tru Turn or Dave Brown. I just mentioned them because they are as good as any of the other brands, come with an adapter that sometimes even fits the engine and cost a bunch less then the others. Just no three blades that I have found. At one point Tru Turn was cutting the slots for your prop size for free so I got on that band wagon and got a couple. Colin, I don't even agree with me very often!!
1 Post
Hi Ghost & Gray Beard,
The three blade spinners that I have purchased, (2.5" and 3") come with a Magnum header card, (manufactured by???) and have been purchased through my local club member/supplier Ivan Southwell. He tells me he sources them from Austars Models.
Gray Beard I would rather agree with you than myself.
Cheers,
Colin
Cheers,
Colin
